2000 chevy 3500 5.7 liter
Old Jul 25, 2018 | 8:11 PM
tymicgab1's Avatar
Default 2000 chevy 3500 5.7 liter
For the last two years my truck has haunted me. It runs with about 90 % power. If I floor it, it slows down. When i'm cruising any speed its seems when I go up hill it will shut down to about 10% power. for two years. I have changed plugs, wires, coil, maf sensor, egr valve, throttle air mixture sensor, throttle position sensor. About a week ago it started this. You start it and it runs for about 10-30 seconds if you turn the key again, nothing. If you turn the key off and then start it runs for 10-30 seconds. When it stalls it stumbles. if you spray starting fluid in the throttle body it will run as long as you keep spraying. It has between 40-50 psi fuel pressure constant never drops, no intake leaks.
Help
Old Jul 27, 2018 | 11:21 AM
tymicgab1's Avatar
Default thanks
Thanks for all your help everybody. I fixed it
