2000 Chevy Silverado 2500HD 4x4 Abs and brake light intermittent problem
Old May 1, 2018 | 3:05 PM
Jacob.Bell1107's Avatar
Question 2000 Chevy Silverado 2500HD 4x4 Abs and brake light intermittent problem
Hi all,
This is second post on this truck as I didnt want to clutter first post with multiple problems. I am intermittently having my ABS and Brake lights on dash pop up. Ive read that theres a possible recall on hub assemblies for this truck that could cause the problem and Ive read that this is a very common problem for this year and model. Any ideas as to how to fix this problem would be much appreciated. Fuses are fine. And not sure if it matters in relation to this problem, but the cable that goes to parking brake is broken. Thanks so much!
Old May 3, 2018 | 11:12 AM
hicksvilleshick's Avatar
You'll need to pull the codes, you'll need something that can pull ABS codes, that will give you a better direction.
Abs modules are notorious for going south.
