2000 Silverado 5.3 oil on outside of trans pan, oil pan
Old Mar 20, 2016 | 1:36 PM
Sonicd's Avatar
Default 2000 Silverado 5.3 oil on outside of trans pan, oil pan
I changed my oil today and again I found oil all over the outside of the oil pan bottom, trans pan bottom, trans cross member, exhaust pipe in front of cross member. After looking at the front of the engine, I saw that there was oil on the rack & pinion steering gear passenger side mounting bolt location. That being the front most point that I see oil dripping, it leads me to believe that my oil pump may be leaking.
Has anyone else had this same problem? I like to work on my own truck as much as possible to save money and to learn. Any help would be greatly appreciated.
Sonic
