2001 2500 HD Crankshaft sensor relearn ?
Old Aug 2, 2016 | 9:45 AM
tlittle's Avatar
Default 2001 2500 HD Crankshaft sensor relearn ?
Check engine light was flashing at freeway speeds after reading several posts I replaced the crankshaft sensor light went away and have had no issues. The truck set for about a week, started it yesterday and sounded like it was running on 6 cylinders, (6.0 litre) ran the code and the dreaded P0300 came up. On some of the posts on here people were talking about having to go to a dealer to have the crankshaft sensor relearn done.
My question, can someone explain the procedure and why? also do I need to have this done. One thing that was discovered is that the tensioner pulley for the A/C was locked up I removed the belt until the tensioner was ordred started the truck and has ran fine sense..... Please help.
Old Aug 2, 2016 | 1:31 PM
cleveland63b's Avatar
sounds like you need to figure out where your misfire is, flashing light means you have a dead miss and if you can tell its not running right then its not just a relearn issue.
You just need a capable scanner to do the relearn but it won't learn or won't be accurate if the engine is running rough
