2001 Dim running lights
Old May 25, 2020 | 1:27 AM
Dariders2004's Avatar
Default 2001 Dim running lights
Having an issue with tail lights being dim.....checked junction box and plugs and no change to lights ...thanks
Old May 25, 2020 | 6:54 AM
With a multimeter check at the sockets to see if you are getting a full 12 volts. Check the lenses to see if they are fogged up as they sometimes do when they get old.
Old May 26, 2020 | 8:18 AM
chem_man's Avatar
15 Year Member
I would also check the wiring to body ground connections in that area to make sure they are clean and tight.
Scottynitro
Mar 24, 2015 4:24 AM
Rltkktlr
Mar 3, 2014 10:52 AM
duramaxedout
Oct 3, 2008 10:20 PM
Foxracerac
Nov 6, 2007 10:14 AM
26tahoe
Aug 19, 2006 3:43 PM
