2001 silverado 4.8L Evap code p0446 won't open Purge Solenoid
Old Jan 30, 2024 | 3:17 PM
GunJam's Avatar
Default 2001 silverado 4.8L Evap code p0446 won't open Purge Solenoid
Hello
Ive done some testing and it appears that the purge solenoid won't open.
1) If I apply an external 12V source to the purge solenoid it will open.
2) a test meter shows 12V at the 2 wire connector for the purge solenoid
3) If a test light is placed between the red(ish) wire and ground the light comes on
4) If a test light is placed across the red(ish) and green wire the light does not come on
This is true with the engine running or just ignition on with engine near operating temps. is there a condition that needs to be met for the purge valve to open other that having the key in the run position?
I suspect a ground issue which is why im getting 12v with a meter but not with a test light.
does anyone have a wiring diagram that shows where the ground for this circuit is located or can suggest a spot to check or give a reason why that valve wont open other than what ive observed?
Thanks!
Old Jan 30, 2024 | 4:07 PM
Yes it needs to be commanded open by the computer or a bidirectional diagnostic tool
diagrams are on charm.li or gmupfitter.com
Old Jan 30, 2024 | 4:41 PM
GunJam's Avatar
Nice.
I found the diagram I need... I see a fuse.
Ill get back to you on this.
Thanks!!
couchmusician
May 19, 2020 4:30 PM
kenurb
Avalanche
May 7, 2019 4:15 PM
tvtahoe
Oct 17, 2014 9:35 PM
jameslbeach
Jan 20, 2012 2:03 PM
JRT600
19
Jun 4, 2009 11:44 AM
