2001 Silverado misfiring check engine light flashing but no code
Old Sep 13, 2019 | 11:28 PM
Christian Patbergs's Avatar
Default 2001 Silverado misfiring check engine light flashing but no code
I have a 2001 Silverado it’s 6.0 swapped and started misfiring, the check engine light flashes when moving but when sitting still it doesn’t flash but when I plug it into a scanner no codes popped up and I have tried multiple scanners
Old Sep 14, 2019 | 6:21 AM
oilcanhenry's Avatar
I'd suspect an ignition issue. 18 year old vehicle could be many things. I am thinking vacuum leak or TBI issue myself. I'm an old dude so hooking up a vacuum gauge, not used much anymore, would be a good start. Before OBD, that was used all the time. It likely will fluctuate but its a good start if the OBD II isn't showing any codes.
Old Sep 26, 2019 | 7:27 AM
Ricardowelch's Avatar
I have a 2001 Silverado it’s 6.0 swapped and started misfiring, the check engine light flashes when moving but when sitting still it doesn’t flash but when I plug it into a scanner no codes popped up and I have tried multiple scanners. Visiting Autoguysland site to know what we should do when check engine lights on but no codes if you concern.
It is probable cause as ignition system Fault- spark plugs, Ignition wires or Vacuum leak Injector fault High or low fuel pressure. You should check them.
YAQUEZ1998
Dec 7, 2017 10:34 AM
abergwi
13
Jan 25, 2015 4:55 PM
arrow64
Dec 9, 2012 9:59 AM
kkmbler
Nov 9, 2012 2:15 PM
ONLYNAMRICA
Jan 27, 2011 4:02 PM
