2002 5.3 Fuel Injector Shenanigans
2002 5.3l
Truck ran OK, but long term fuel trim was way too high.
Replaced injectors with Delphi, same brand and part number as the old ones.
Install went OK.
What I forgot, was I had unplugged 1 coil, and left the fuel pressure regulator unplugged when I first started it.
It idled like crap, then realized, plugged them back in properly.
Truck still ran like crap. Later in the day, come to find the engine not cranking, like it was locked up.
This morning I pulled the plugs, and wires, which were all DEFINITELY toast, gas poured out of the plug holes.
Manually turned the motor, seemed ok, not locked up.
Oil dipstick smells like gasoline, so I will be changing the oil.
I have new ACDelco Iridium Plugs and new wires on the way.
So my question is, should I try running it with new plugs first? Or should I try something else for fuel injectors.
(Side note: I now have 0 fuel pressure, I can hear the pump for a second when I turn the key, I’m assuming this may be because I emptied the fuel rails of fuel, and haven’t ran the truck yet, so the vacuum for the fuel pressure regulator hasn’t run at all)
Any help is greatly appreciated, thanks!
Install went OK.
It would help if you posted the codes you received at the time you got the fuel trim info.
Better yet, if we were able to see the data stream info , can you post that info, thanks.
oilcanhenry (August 20th, 2022)
I found the issue, and it’s the fuel injectors, I got junk knock offs, for being cheap. I need new ones. Should I spend $150 on refurbished ones? One of my old injectors broke the harness plug.
Hey Hanky, thanks for the reply. I originally threw p0171, bank 1 too lean, STFT was about -2 through positive 3 both sides, LGFT was at 25, both sides. After replacing fuel injectors I got code p0300.
