2003 GMC Sierra loses power when trying to start.
Old Dec 4, 2020 | 6:37 PM
Joey G's Avatar
Default 2003 GMC Sierra loses power when trying to start.
I have a 2003 GMC Sierra that rides on air suspension sitting on 22's that I can't figure out why it wont start. When I attempt to start the truck and turn the key to turn the accessory power on, everything seems fine. But when I turn the key to actually crank it over to start it, theres ONE decent sized POP coming from under the dash and then the truck loses all power. The power seems to stay off for a varying amount of time but usually after an hour or two, truck once again can turn the accessories on but if I attempt to start it, same pop and loss of power. Truck has a 4.8 in it, reg cab short bed. Air compressors run off their own battery. Any help would be beyond greatly appreciated. Plz email me if you have has this problem before and know how to fix. Thanks
Joey.p.gokie@gmail.com
Old Dec 5, 2020 | 2:56 AM
oilcanhenry's Avatar
Any OBD II codes for us? Miles? Fuel pressures? Does it start with a shot of gas? How long since ignition was done?
Old Dec 5, 2020 | 5:15 AM
Joey G's Avatar
I couldn't get the truck started so I wasnt sure if the check engine light would stay on but I dont have a reader so havent been able to check for codes yet. 104k miles. Fuel pressure is fine, I changes the fuel filter because she sat for a good 9 years or so before I started driving her again recently. I've owned the truck since 48k miles and I've never had the ignition done. Good news, she randomly started today after I messed with a few things and I was able to drive back to my home. I ran a test light threw the fuse box that's in the engine bay and the fuse labeled CRANK (PCM) was the only one not showing a good connection. I pulled it and it looked good so I put it back after a few mins, I also had hooked a battery charger up to my front Optima overnight ( because why not ), and figured I'd give starting a try before I gave up for the day and she started. She definitely wasnt idling properly and felt like she was going to stall if I didnt keep one foot on the gas. I parked her and that was last night. I have no clue what to even check next. The help is beyond appreciated!
tnjwhite2
Jun 2, 2018 11:35 AM
SpunMufflerBearings
Jun 30, 2010 11:57 AM
Chevy_Guy6809
May 31, 2010 12:07 AM
country_09
Jan 29, 2010 11:54 AM
