2003 Silverado Blower Resistor
Old Feb 10, 2021 | 6:10 PM
Tony Fracisco's Avatar
Default 2003 Silverado Blower Resistor
Shut my truck off the other day and the heater kept running. Found on Google that it was more than likely the blower resistor. I bought the new resistor and ran into an issue. There is a 3 wire plug coming from the truck and the new resistor has a 7 wire plug. I bought the wiring harness and connect A wire to A wire, B to B and C to C. Leaving the remaining 4 not connected. When I turn the truck on the heater will not blow. Does anyone have any suggestions? I checked the connections. They seem good. It's been in the negatives all week and is only going to get cooler. Negative 41 to be exact. I would really like to have heat when takeoff the daughter to daycare. Any help is appreciated.
Old Feb 14, 2021 | 3:39 AM
chem_man's Avatar
15 Year Member
There are three different resistor modules (actually 2 resistor packs and 1 power module) for the 2003 Silverado. Which particular part you need depends on the HVAC options for your Silverado. You can go to https://www.4s.com/en, put in your year, make and model, select blower motor resistor and the three choices will show.
Good Luck
69ragtop
Aug 28, 2017 11:24 PM
stevo8
Avalanche
Apr 25, 2016 4:34 PM
murphbradyscott
Feb 12, 2012 5:10 AM
atc31510
May 29, 2010 1:50 PM
05colorado
Dec 5, 2008 2:50 PM
