2005 4.8 oil filler tube
Old Jul 28, 2016 | 12:04 AM
alan07's Avatar
Default 2005 4.8 oil filler tube
Can someone tell me how to remove the oil filler tube from the valve cover on my 2005 1500 4.8.
Oil is bleeding from around where it's connected to the top of the valve cover.
I thought it was just a friction fit, but I guess I'm wrong.
Any help is appreciated.
Alan
Old Aug 5, 2016 | 9:17 AM
Shocker6699's Avatar
Default Oil Filler Tube
Alan
My filler tube is held by a bracket that has a bolt on the lower part at the engine block just below the Valve Cover. My engine is also a 4.8 Litre block.
Old Aug 5, 2016 | 9:21 AM
Default Oil Filler tube
My oil filler tube was replaced by an after marker and original was also held by an O-ring at Valve cover. Maybe the O-ring is seized and just needs some work to break loose.
Old Aug 6, 2016 | 12:29 AM
cleveland63b's Avatar
should just have to turn and pull...I believe turn it counterclockwise
