2005 Chevy Silverado 1500 5.3 rough idle, stall, backfire...
Old Apr 1, 2017 | 11:13 AM
Heinz's Avatar
Default 2005 Chevy Silverado 1500 5.3 rough idle, stall, backfire...
Truck sat over a weekend. Went to start idle momentarily then died. Then it wouldnt idle, had to give it throttle to keep from stalling. Next day worse, didnt wanna start then it sounded like a backfire when it did.
I checked fuel pressure, lines and oil leaks and it was all good.
Old Apr 2, 2017 | 9:31 AM
NDChevy's Avatar
Have you put a ODBII reader on it to see if it's throwing a code?
As to possible causes, bad gas, mass air flow sensor, throttle body position sensor would be possible candidates. Cam position sensor might be a possibility as well, but not positive on that.
