2005 heater problem
Old May 15, 2016 | 12:56 PM
alan07's Avatar
Default 2005 heater problem
The vents on my 05 Silverado began blowing only hot air this morning. Even both slide temp switches are at the bottom (cool) it still blows hot air. All other blower controls work OK. I've checked fuses and all are good.
Any advice is greatly appreciated.
Alan
Old May 15, 2016 | 11:18 PM
hicksvilleshick's Avatar
Any new noises? I know that the blend door actuator can be problematic but I think that only effects where the air is coming out.
Old May 16, 2016 | 6:54 AM
The blend door actually controls the mixture of hot and cold air. This is probably your problem. The mode door actuator controls which vents are being used. This is another actuator and they work separately from each other.
Old May 16, 2016 | 8:58 AM
There ya go. I wasn't sure if I was remembering right. Thanks for clarifying.
