2005 Trun signals and DRL not working
Old May 7, 2016 | 11:35 AM
USAF1stSGT's Avatar
Default 2005 Trun signals and DRL not working
First my turn signals are not working on my 2005 Silverado. I have replaced the rear turn signal bulbs, front are operational, I replaced all the turn signal fuses and the module, I even tried new flasher relay's. Any suggestions.
My DRL also are working, replaced bulbs and relay.
All other lights and the 4 ways are working.
Any suggestions,
Old May 7, 2016 | 2:10 PM
what conditions are you checking the dtrl? if the high or low beams are on, the dtrl are switched off.
the truck must be running, in drive, e-brake released and daylight present at the ambient light sensor. fluorescent lighting will not be detected by the light sensor.
Old May 8, 2016 | 11:24 PM
Matt Sims's Avatar
Have you checked the multi function switch for any melted or burnt wires or plug this is common in fords....
