2006 2500 HD stuck in Park
My 2006 Silverado 2500HD Duramax Diesel in now stuck in Park. It started with my brake lights not working and no power to rear brake lights. Replaced the Brake Pedal Switch per suggestions on the net and still no brake lights but now I can't shift out of Park.
When I disconnect the wiring harness to the switch then I can shift normally. I replaced the switch 2 more times with the same results.
Any ideas are welcome. Thanks.
But it sounds like something related to your brake switch which your lights and brake lock are tied to.
Are you sure you're getting a good part? Might need to check the wiring and see if something is cut or skinned.
