2006 2500HD Duramax A/C Trouble
Old Jun 25, 2016 | 5:03 PM
JHH452's Avatar
Default 2006 2500HD Duramax A/C Trouble
The compressor clutch isn't engaged. Checked fuse,OK. Changed relay with no change. No voltage to relay switch terminal. What is the next items to check?
Old Jun 25, 2016 | 6:56 PM
Rednucleus's Avatar
If charge is low compressor won't engage to protect it. Just had to have our '05 Sub evaporator core changed. 1st symptom was no compressor.
Old Jun 25, 2016 | 8:08 PM
hicksvilleshick's Avatar
Make sure you've got enough freon in the system.
Old Jun 26, 2016 | 11:48 PM
the ac relay with key on should have power at 2 pins, open circuit on one pin and 1 should have grd.
