2006 Silverado 1500 no rear lights
Old Jan 6, 2022 | 10:49 AM
darthjdsmith's Avatar
Default 2006 Silverado 1500 no rear lights
I have a 2006 Silverado 1500. All three brake lights, rear tail lights, and license plate lights have stopped working. Fuses are good but have no power to them when I checked them with a multimeter.
Old Jan 15, 2022 | 3:40 PM
2001 chevy silverado's Avatar
pretty simple. from the fuse there is a wire run (packed with other wires) back to the back - and that needs to have +12V. separately, the lights will likely used -12V ground off the frame. i can't remember it could be 2 wire not 1 wire (both +12V and -12V from fuse box).
you haven't said if there's a "trailer module" around the spare tire. there's plugs under the bumper. you didn't say you checked.
you probably shouldn't post questions unless you checked for power at the easy places yet ?
tweber27
May 22, 2017 1:16 PM
hoghntr1987
Mar 7, 2014 11:22 AM
woodoak
May 26, 2013 2:42 PM
skdevore
Aug 26, 2009 10:18 PM
duramaxedout
Oct 3, 2008 10:20 PM
