Alot of smoke
Old Jul 10, 2022 | 8:36 PM
donovaki's Avatar
Default Alot of smoke
The truck smokes a lot on cold starts in the morning and after work. It is an 07 1500 classic 5.3. It's either blue or a combination of blue and white. I found a lot of metal glitter in my oil that had 3k miles on it so I changed the oil and valve stem seals. I added the Lucas heavy-duty oil stabilizer as well. It still smokes a lot and goes through coolant very slowly, but smokes a lot more when I top it off. when at about 5500+ rpm, it will blow a cloud of white smoke from the exhaust. Under the valve covers looked very clean with no sludge at all when I was in there. The truck also makes a slight ticking when idling but runs and drives absolutely fine. Thank you in advance for any info, tips, or answers.
Old Jul 12, 2022 | 12:07 PM
oilcanhenry's Avatar
Is the smoke white or blue? You said white. Is the engine oil dropping, so that you have to add oil? How about the coolant? How much/ often do you add it? Good idea changing the valve stem seals.
Bill_The_Army_Meconic
Oct 2, 2016 4:45 PM
Viperx15
15
Jan 16, 2015 6:53 AM
mmoore031908
Mar 14, 2014 8:39 PM
kobiewhite
Feb 23, 2009 2:26 AM
smitty
Nov 11, 2007 7:51 PM
