Brake Bleeding Problem
Old Sep 20, 2019 | 6:07 PM
Larrycarol's Avatar
Unhappy Brake Bleeding Problem
I have replaced all the brake lines and hoses on my 2003 Silverado 1500 4Wd. I had no problem bleeding the front brakes, but I can't get fluid through the back brakes. Is the abs system somehow blocking the rear brake circuit?
Old Sep 20, 2019 | 8:13 PM
it may have a proportioning valve at the master cylinder...you would need a proportioning valve tool to be inserted to bleed the rear brakes. post a pic of the mc
Old Sep 21, 2019 | 11:58 AM
Larrycarol's Avatar
Default Proportioning Valve Tool
I have one of those tools. When I screw it down on the valve, will it center the piston or do I have to do something along with it?
Old Sep 21, 2019 | 3:31 PM
remove the rubber cap...slide the tool into place bleed brakes.
if this doesn't make sense post a pic of your tool and the mc
Fishinfooleric10@aol.com
Aug 14, 2011 4:41 PM
cumminbr
Jun 2, 2011 9:14 PM
Jfandrich
Feb 28, 2011 10:31 AM
chevy3quarta
Jul 27, 2007 5:19 PM
