brake and steering issues
Old Aug 27, 2018 | 1:51 PM
dusted's Avatar
Default brake and steering issues
changed rear calipers and rear brake lines. Bled brakes, started the truck and have no brakes and no power steering. Fluid levels are fine.What am I missing? Its a 2002 2500hd.
Old Aug 27, 2018 | 6:13 PM
geo1's Avatar
A little more info,you bled brakes,rear only?and by using pedal?and had firm pedal and lost it on start up?
Old Aug 27, 2018 | 6:48 PM
dusted's Avatar
bled rear brakes using pedal. never had a good pedal. lost brakes and power steering on start up. had no problem with steering before doing the brakes. don't know if this has something to do with the hydroboost? thanks
Old Aug 27, 2018 | 7:00 PM
geo1's Avatar
So,you had a leak in rear line,changed calipers cause you couldn't open bleeders,I'm just thinking the system was open for awhile,bleed the fronts, sometimes you got to take it slow,5 easy pedal pumps,then bleed,repeat,do all corners
Old Aug 27, 2018 | 7:22 PM
dusted's Avatar
ended up bleeding the fronts too. Trying to figure out why the power steering doesn't work. and its not providing boost for the brakes. there was no problem with steering before.
Old Aug 27, 2018 | 7:35 PM
geo1's Avatar
On a guess,master cylinder went sour,not returning,you could loosen master a bit,check the activity,rod moving back on release of pedal,and hey,stuff happens,call it luck,all bad luck,like I have,lol
