A/C chatteriring a/c problems
Old Jul 12, 2017 | 6:45 PM
02_silverado_silver's Avatar
Default A/C chatteriring a/c problems
ok I have an 02 Silverado 4.8 2x4 extended cab
now for a little while I notice I loose a little cold air for a second or 2
rev engine and only around 1500 RPM I hear a loud chattering sound
found out it was a/c tensioner doing the noise replaced it and it did the same thing and blew the new tensioner apart changed again and it lasted a day or 2 and blew it up again
in the box with the new tensioner has a WARNING bulletin
#03-01-38-019a
dealer says I need to replace whole a/c system
compressor some a/c hose and acc and put in a filter
AC delco number 15-10413 is this filter needed for this issue
what exactly needs to be replaced to fix this issue
