A/c clutch fuse keeps blowing
Old Jul 23, 2017 | 5:10 PM
rebranger's Avatar
Default A/c clutch fuse keeps blowing
I have a 2004 Z71, 5.3 V8, auto. All of a sudden the A/C clutch fuse began blowing. Disconnected connector on compressor, NO fuse blowing. Replaced A/C compressor, vacuumed & re gassed, A/C works fine for about 30 min, then blew another fuse. Removed plastic bottom shield (shroud) to get to wiring harness which was grommet-ed (attached) to around exterior of oil pan/block junction. Removed protective plastic wire shield. At the juncture of the wiring harness split on the passenger's side, the wires were very warm to the touch, no smoke, no burned wires, no shorts that I can find. It appears to be a bad connection in the circuit or a bad sensor somewhere. Anybody have any ideas of what/where to check next? PCM under hood had a 10 amp fuse, replaced it with a 20 amp, A/C ran a while (20 min, normal driving) then blew again!!
Does the engine temperature sensor (drivers side towards front) have anything to do with this clutch control circuit?
Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
Old Jul 23, 2017 | 6:47 PM
kevinkpk's Avatar
If the wires are warm, it's either undersized wire, or loose connection drawing current/heat.
