Changed from 862 heads to 706 heads and no start
Old Jul 28, 2022 | 2:27 PM
HRankin5.3's Avatar
Default Changed from 862 heads to 706 heads and no start
I had a problem with broken manifold bolts in my 862 heads so I found some 706 heads to run that we’re all ready to go. I put a new head gasket on as well and got the whole engine together. Went through a got oil into the heads and when I went to crack it over to start it rev up than stall. Sometimes I says to check oil pressure. I’m not sure if the timing is off or if something happened to my oil pressure sensor while the engine was apart.
Richardx2
Feb 26, 2014 4:21 PM
stewroids
Feb 29, 2012 7:30 PM
thekinzuakid247
Sep 29, 2007 2:58 PM
