code P1345
Old Apr 20, 2022 | 5:53 AM
bcoolair's Avatar
Default code P1345
I have 2000 chevy c2500 with5.7 vortec. Had fuel pressure regulator replaced ( under the upper intake ) 1st regulator was wrong so cylinders filled with gas. removed plugs and cranked motor to blow out gas. There were a couple lowed bangs. Replaced with correct regulator. Now have code P 1345. Replaced both crank and cam sensor, reset codes but still have code......PLEASE HELP
Old Apr 20, 2022 | 2:14 PM
kevinkpk's Avatar
Check the timing.
Old Apr 20, 2022 | 7:51 PM
oilcanhenry's Avatar
I hope this info will help you out:
|What is P1351 CHEVROLET code meaning?
The Ignition Control Module (ICM) has independent power and ground circuits. The circuits between the ICM and the Powertrain Control Module (PCM) consists of the following circuits:
-The ignition control (IC) timing signal
-The IC timing control
-The low resolution engine speed signal
-The medium resolution engine signal
-The camshaft position signal
-The low reference
The ICM sends 3X signals to the PCM, and controls the timing advance during engine cranking. The timing advance changes to PCM control after the following actions occur:
The PCM receives the second 3X signal
The PCM applies 5 volts to the ignition control (IC) timing signal circuit.
The ICM monitors the CKP sync signal when the engine is cranking. The CKP sync signal is passed from the CKP sensor to the ICM on the CKP sensor 2 signal circuit. The CKP sync signal is used to determine the correct cylinder pair and initiate the ignition coil firing sequence. The 18X reference pulses are passed from the CKP sensor to the ICM on the CKP sensor 1 circuit. The 18X reference pulses are used for fuel injection and ignition control. After the ICM receives both signals, the ICM passes the 18X and 3X reference signals to the PCM. The CMP and the CKP sensors share a 12 volt reference and low reference circuit. The CKP sensor consists of the following circuits:
-A 12 volt reference
-A low reference
-A CKP sensor 1 signal
-A CKP sensor 2 signal
Old Apr 21, 2022 | 7:27 PM
bcoolair: welcome to the forum. Moving this thread to the C2500 section where it will get more views.
