Disconnect battery now truck won't crank
Old Jan 22, 2020 | 6:55 AM
Agent spliff's Avatar
Default Disconnect battery now truck won't crank
Hello, I had to fix 2 problems with my 2005 Silverado. 1 was brakes and the other was steering wheel bearing. I disconnected the negative battery when I removed the steering column. I put everything back together and the truck will not even attempt to crank. The light with the locked truck comes on but goes off after a few seconds.
I am fairly new to owning this truck and it was the first time I have disconnected the battery on it. I have had a couple of small electrical issues with it, but nothing serious that I am aware of. Just a bad ground for the blinkers and something with the passenger airbag. Never had any problems with it cranking. Seems like it is a security problem or something. Help please.
Old Jan 22, 2020 | 7:13 AM
You stated that you removed the steering column. Possibly somehow the wiring was damaged when you reinstalled the column. I would start by checking this first.
Old Jan 22, 2020 | 8:57 AM
That was the first thing I tried. I checked every clip and connector. Everything seems fine. All power options etc work. Just won't send power to the Starter for some reason
Old Jan 22, 2020 | 2:18 PM
Does the truck have an anti theft system that might be causing the problem?
Old Jan 22, 2020 | 3:38 PM
Yes it does. The anti theft light turns off after a couple seconds. I tried doing the recode key method of 10 minutes in on position 3x. Still nothing. I have checked every fuse. I am considering putting in a new ignition switch. I never had a problem with it... But I am completely unsure of what it could be.
Old Jan 22, 2020 | 4:35 PM
kevinkpk's Avatar
Look at the neutral safety switch, that would keep it from cranking, also try it with shifter in neutral.
Old Jan 24, 2020 | 10:35 AM
Yup. The problem was the cable for the neutral safety switch. It was not moving correctly. I got her running now
ctlawless
2007 - 2013 (GMT900)
61
Apr 4, 2024 1:54 PM
GoRacers
Jun 25, 2019 11:39 AM
pepperjackom
Jul 31, 2017 6:20 AM
ex0r
May 27, 2015 8:49 AM
doug48725
Astro
Dec 10, 2012 8:24 PM
