Drive shaft hum
Old Nov 29, 2020 | 4:38 PM
Tyson Bishop's Avatar
New User
Awaiting E-mail Confirmation
Default Drive shaft hum
I have a 2001 Silverado 2500, crew cab 4wd, short bed. I recently had a one peice drive shaft made from aluminum. Now I have a fine vibration that's strongest at 50mph. It goes away after 60. How the hell do I get rid that? It drives me crazy. Its not ridiculous, just extremely annoying.
Old Nov 29, 2020 | 7:16 PM
I wonder how you can tell it's the driveshaft. Anyway if you're sure, then you need to get it balanced.
Old Nov 29, 2020 | 10:37 PM
PNW NBS Z71's Avatar
If you did not have the problem before the new shaft, then I have to agree with @mountainmanjoe and pull the shaft and have the balance rechecked.
Old Mar 11, 2021 | 8:27 PM
Bnlfan's Avatar
Default Simular issue....2000
I have a 2000 Silverado 1500 4 wd. I had the same issue and it was the U Joint.
Also, pop the cover off the rear differential and check the teeth on the gears. I found the one I have had previously been rebuilt and the lazy person who put it together left the washers off behind the satellite gears.
Be careful with that drive shaft. I didn't correct my vibration in time and the U joint at the rear end came off. The shaft bounced under the truck while I was running 70 mph. Now, I am having a hard time locating a replacement drive shaft. So, be careful letting that vibration go unchecked.
MrAxtell69
Jun 19, 2020 6:32 PM
blacknastalga
Jul 19, 2017 11:03 AM
DavidChander
Feb 4, 2014 6:24 PM
RitualJman
Jun 5, 2013 10:21 AM
socplay50
Jul 10, 2012 10:00 PM
