Electrical issue??
Old Feb 2, 2021 | 12:53 PM
Ron83's Avatar
Default Electrical issue??
I have a 2006 Silverado Z71. I'm at my wits end trying to figure out this problem. The ABS and brake light comes on and it says service brake system on the dash. Right before this happens the headlights dim. After the warning lights come on the speedometer bounces all around and the truck won't shift past 2nd gear. Sometimes it doesn't do it and drives and shifts perfectly normal though. I've replaced both front wheel bearings with speed sensors. I've cleaned all the grounds I could find. I replaced the VSS. It's still having the same problem. I will be extremely grateful to anyone who can help me figure this out.
Old Feb 2, 2021 | 1:33 PM
Apparently it's a common problem. Bad wiring harness to frame grounding point. Directly underneath where you sit.
Ron83
Feb 2, 2021 12:52 PM
elgrandioso01
Jan 21, 2016 8:33 PM
slamjam434
Dec 2, 2014 2:33 PM
rick323
Sep 1, 2012 2:04 PM
JoeCB
Avalanche
Jan 19, 2009 10:53 PM
