Emissions issues P0171 and P0174
Old Feb 26, 2026 | 8:07 AM
Syncman's Avatar
15 Year Member
Default Emissions issues P0171 and P0174
GMC Sierra 1500, 2004, 4.3L, 260,000 miles.
What would be the most likely cause of failure? Is there a common part that would cause both a bank1 and bank2 failures at the same time? Unfortunately I live in a county that requires emissions testing, and Im hoping its not a Catalytic converter issue.
Whats most likely issue for a C0291 Park brake unlatch relay circuit code?
Many thanks. I dont want to just start changing parts, till it goes away.
Old Feb 27, 2026 | 5:58 PM
chem_man's Avatar
15 Year Member
The first thing I would do is to check your short and long term fuel trims to verify that the engine is indeed running lean.
If your engine is running lean, then start by looking for a vacuum leak such as around the throttle body, the intake manifold, etc. If you can get hold of a smoke generator and perform an EVAP system smoke test. It can reveal "hidden" leaks in the EVAP system and pinpoint vacuum leaks as well. (FYI, I recently purchased one for about $65 on amazon and it is fantastic - wish I had purchased one years ago!)
Another thing to check is your fuel injection system pressure and MAF sensor operation.
As for the C0291 goes that is a DTC for the ABS motor relay circuit or low voltage problem and not a DTC for the parking brake unlatch relay circuit. I would check the electrical connections and grounds for the ABS pump.
Good Luck!
Good Luck!
ve6bmw
1988 - 1998 (GMT400)
Apr 22, 2018 6:02 PM
ve6bmw
Apr 16, 2018 9:45 AM
Jeremyleronson
Oct 16, 2017 9:46 PM
Chevrolet_girly
Sep 29, 2013 10:26 PM
alno1995
Mar 1, 2010 6:52 AM
