Engine just shuts off while driving
Old Dec 8, 2023 | 1:49 PM
ARTWRK's Avatar
Default Engine just shuts off while driving
My 2003 silverado 2500hd 6.0 just shuts off while driving and then restarts in about 2 min
Old Dec 8, 2023 | 2:44 PM
chem_man's Avatar
15 Year Member
Are there any Diagnostic Trouble Codes (DTCs) present in the OBDII system? Is the Check Engine Light or Reduced Engine Power Light illuminated? How often does the engine die?
I had a similar problem with a 1992 Oldsmobile. However, it would only die once every six months or so, hence it was extremely difficult to diagnose.
Old Dec 8, 2023 | 3:28 PM
ARTWRK's Avatar
No engine lights or codes engine just dies this happens a few times a day
Old Dec 8, 2023 | 5:09 PM
try monitoring your fuel pressure
Old Dec 9, 2023 | 11:41 PM
chem_man's Avatar
15 Year Member
I agree with mountainmanjoe. Check your fuel pressure and make sure it is within factory specifications. Also, check the wiring to the fuel pump as well as the wire that goes from the fuel pump electrical connector to ground.
Good Luck!
dave92451
Mar 3, 2020 12:37 PM
nonricer
Dec 29, 2013 5:55 AM
MOTOX
Feb 26, 2013 6:40 PM
farmall51
Jul 5, 2011 8:15 PM
GreatWhite6.0
Nov 13, 2006 5:47 PM
