Engine misfire
Old Jun 5, 2022 | 6:00 PM
CollinW's Avatar
Default Engine misfire
So a little while back my trucks idle was rough and my CEL was flashing but it went away after a little while and then a week or so goes by and my CEL turns on but not flashing. I pulled codes both times. And they both were the same codes, P0300 P0174 and P0151 I thought it would be my coilpacks sense it has to do with eletrical and fuel but I spoke with others and they think it might be something else. Any help would be appreciated. Thanks.
Old Jun 5, 2022 | 9:51 PM
chem_man's Avatar
15 Year Member
Check the wiring to the upstream oxygen sensor on the passenger side. If the wiring is intact, replace the oxygen sensor. If the ECM cannot read the data the oxygen sensors are sending to it, or if the oxygen sensor is not working, it can cause all kinds of issues.
If after repairing the wiring to the O2 sensor or replacing it, and the P0300 and P0151 persists, come back for more guidance.
Good Luck!
xrjoe
Mar 24, 2023 4:25 AM
TruckKnight
2007 - 2013 (GMT900)
Nov 18, 2021 8:52 AM
Cshort6469
Oct 27, 2021 6:46 PM
nsisk01
Jun 25, 2019 3:03 PM
Cargirl2017
Dec 19, 2016 7:20 PM
