Evap leak
Old Dec 28, 2015 | 12:54 PM
69vette427's Avatar
New User
Awaiting E-mail Confirmation
Default Evap leak
I know this subject has been beat to death. I have a 2005 crew cab 1500
silverado. I have replaced the evap solenoid and valve. Put smoke into the system and seen nothing. I did not have this problem until the truck was driven over a large pot hole. Is there a chance that something was jarred loose on the fuel pump? I'm about to remove the bed to get a good look at the pump and hoses. Been having this problem for over a year now.
Old Dec 28, 2015 | 5:03 PM
chevy55's Avatar
did you check the purge solenoid also while you were at it.if not maybe your purge valve is bad and causing your issue.
Old Dec 28, 2015 | 10:52 PM
cleveland63b's Avatar
what code? and which solenoid did you replace?
Old Jan 1, 2016 | 1:30 PM
ihgnah's Avatar
If there isn't any smoke that you see when you smoke test it, getting a better look at the hoses might not be necessary lol. DTC's would be helpful though if you could post them.
