filler neck overfill hose
Old Jan 2, 2020 | 4:36 PM
Kstay's Avatar
Default filler neck overfill hose
Hi,
I have a 2005 chevy Silverado 1500 and was wondering should I replace the whole filler neck or just the overfill hose that's broke. Is this a pain in the rear to do.
Old Jan 2, 2020 | 4:39 PM
not sure what a overfill hose is? are you referring to the refueling vapour recover pipe that is part of the filler neck? post a pic
the vapour recover pipe can't be open to the atmosphere or evap leak codes will set. Its should be replaced for safety...what if you have a rollover. Its not a bad job to replace.
Old Jan 2, 2020 | 6:08 PM
Kstay's Avatar
Yeah that must be what it is. I saw the hose hanging from the filler neck and just assumed it was for overflow. Where does the hose go to, the top of the gas tank?
Old Jan 3, 2020 | 1:05 AM
yes.
its function is to create a vacuum at the top of the filler neck when refueling...this draws fuel vapour down into the tank instead of venting up into the air.
Old Jan 4, 2020 | 7:20 PM
Kstay's Avatar
so I looked at the fuel hose today connected to the filler neck and its just a hose that is capped at the top of the hose? Its not actually into the filler neck itself its just attached to the filler pipe with a bracket. unsure where it goes or what its to. Any help would be appreciated.
Thanks kev
Old Jan 4, 2020 | 9:55 PM
go to rock auto, build your vehicle, find the part in question and post a link. hard to say without seeing what you are talking about.
NeeNee
Avalanche
Oct 13, 2017 7:38 AM
Kims
Jan 5, 2017 10:44 AM
james.reid
Aug 8, 2013 3:17 PM
tjokerst91
Aug 28, 2012 10:29 AM
jpatterson6136
Nov 19, 2011 10:40 AM
