Heater on entire driver side including defrost not working
Old Nov 15, 2018 | 1:53 PM
lorilou79's Avatar
Newly Registered
Default Heater on entire driver side including defrost not working
2004 Chevy LS Extended Cab - Entire Driver side including defrost & floorboard blows cold air only. The passenger side works fine. We've had the battery replaced & during the summer had the AC recharged as well. My mechanic said he would have to take the entire dash out??? Any idea what it could be & is it necessary to pull out the whole dash to fix?
Old Nov 23, 2018 | 12:15 PM
Perkins315's Avatar
Default Blend door
My jeep had this issue. It had a two part blend door. This door controls heat or cold control. One side of the two part door was broken.
Old Dec 7, 2018 | 7:04 PM
ladance's Avatar
Default Any further analysis on this issue?
My 2006 Silverado just started doing something similar. Air was working fine, but now the driver's side controls only blow very hot air, while the passenger side blows cold,
Today when I shut the truck off and turned it back on, I got the cold air to work on left and right controls initially, but after 3-4 minutes, the hot air on the drivers side starts blowing again. Passenger side is fine.
Thoughts or suggestions as to the cause or fix?
Old Dec 7, 2018 | 8:06 PM
ladance's Avatar
Found some youtube videos that show replacement of the AC actuators that control the AC/heat functions. Just do a YouTube search for replacing the actuators.
Old Jan 19, 2019 | 7:34 PM
Creel228's Avatar
Default Actuators
I had the same problem so I replaced the actuator on my 04 Silverado. One is below the dash, right at the hump. There’s a black plastic piece covering it. It’s easy to replace and costs about 30 dollars. I was told there’s another one but it’s in the back of the dash and the air bag would need to be taken out. I would try the easy one first.
