high idle after cleaning injectors
Old Feb 9, 2024 | 10:47 AM
metalrain's Avatar
Default high idle after cleaning injectors
Gentlemen,
As stated, took the injectors out and cleaned them, everything back together and i have an idle of 1800 rpm. I disconnected the throttle when i removed the injectors, did the throttle body reset a few times,
no change. 15 minute drive at highway speed, no change. Also no codes. what am i missing?
Thanks
metalrain
Old Feb 9, 2024 | 4:00 PM
always post your info please (year/model/engine/miles). Thanks.
Old Feb 10, 2024 | 5:28 AM
metalrain's Avatar
2000 5.3 silverado 1500 4x4
140,000 miles
Old Feb 10, 2024 | 2:13 PM
try smoke testing it for vacuum leaks
Old Feb 11, 2024 | 3:46 PM
metalrain's Avatar
fyi update,
after checking my work, i installed the cruise control cable with one to many turns. Adjusted it back to where it needed to be and idles great.
Thanks.
Old Feb 11, 2024 | 7:18 PM
alderfall's Avatar
Excellent! An easy fix, can’t beat that! Thank you for the update.
red suburban
May 6, 2023 12:52 PM
RJK
Mar 4, 2021 4:22 PM
in2pro
Dec 25, 2020 11:34 PM
jlutty3
Mar 2, 2015 9:33 PM
fyrflie
Apr 16, 2013 2:03 PM
