How do I fix random misfiring
Old Jun 19, 2024 | 1:48 PM
  #21
Originally Posted by quartercenturytruckin
. After 60 seconds psi had dropped to 48.
It should not be dropping 10psi in one minute.
https://charm.li/Chevy%20Truck/1999/...%20Inspection/
3. A fuel system that drops more than 34 kPa (5 psi) in 10 minutes has a leak in one or more of the following areas:
^ The fuel pump check valve.
^ The fuel pump flex pipe.
^ The valve or valve seat within the fuel pressure regulator.
^ The fuel injector(s).
4. A fuel system that drops more than 14 kPa (2 psi) in 10 minutes after being relieved to 69 kPa (10 psi) indicates a leaking fuel pump check valve.
5. Fuel pressure that drops-off during acceleration, cruise or hard cornering may cause a lean condition. A lean condition can cause a loss of power, surging, or misfire. You can diagnose a lean condition using a scan tool. If an extremely lean condition occurs, the heated oxygen sensors(s) will stop toggling. The heated oxygen sensor output voltage(s) will drop below 300 mV. The fuel injector pulse width will increase.
misfire troubleshooting:
https://charm.li/Chevy%20Truck/1999/...t%2C%20Misses/
https://charm.li/Chevy%20Truck/1999/...%20PIP%203056/
https://charm.li/Chevy%20Truck/1999/...s%20Diagnosis/
Old Jun 19, 2024 | 2:24 PM
  #22
quartercenturytruckin's Avatar
Thank you, I'll go through these tonight or tomorrow.
Old Jun 19, 2024 | 10:33 PM
  #23
so I checked the pressure again. From static, pump off, it drops 8 psi in 7 minutes. Did go to 58 psi on wide open throttle. Both actual throttle and pulling vacuum hose from regulator.
Changed the fuel filter and fuel pressure regulator. Same result on all pressure tests. Still drives at +35-40% trim.
From your references, i guess i have a leak somewhere. Either check valve at the pump or in the fuel injectors.
What do you think?
Old Jun 20, 2024 | 11:03 AM
  #24
Scratch that last comment. Fuel pressure does not drop now with the new regulator. Trim is still high.
Old Jun 21, 2024 | 6:43 AM
  #25
Did an injector balance test.
cyl # = charged pressure:after firing
1 = 52:48 pressure drop = 4
2 = 53:44 pressure drop = 9
3 = 54:46 pressure drop = 8
4 = 53:45.5 pressure drop = 7.5
5 = 53:45.5 pressure drop = 7.5
6 = 53:45.5 pressure drop = 7.5
7 = 53:45.5 pressure drop = 7.5
8 = 53:45.5 pressure drop = 7.5
reran the test on 1,2 and 3
1 = 53:45.5 pressure drop = 7.5
2 = 53:44.5 pressure drop = 8.5
3 = 54:44.5 pressure drop = 8.5
In this video the guy was having misfires with anything under a 15 psi pressure drop
Pulled spark plugs, picture attached.
Old Jun 21, 2024 | 12:23 PM
  #26
I fixed the pressure leak and got some more data. What are your thoughts on the fuel injector balance test?
Old Jun 21, 2024 | 1:30 PM
  #27
@chem_man
Old Jun 21, 2024 | 4:36 PM
  #28
chem_man's Avatar
15 Year Member
Regarding the fuel injector balance testing/results, I have zero experience in this area.
Regarding the pictures of the spark plug(s), what I see sure looks like a way too wide gap.
According to the information off of rockauto.com, the factory recommended spark plug is the ACDelco 41-962 double platinum plug, and the factory recommended gap is 0.040". I do know that the Vortec engines are really picky about which spark plugs they like, so be sure and go with ACDelco 41-962 double platinum plugs. Also, do not purchase them from Amazon or ebay as they will likely be counterfeit plugs. If you want to save a few bucks on plugs, purchase them from rockauto.com as they use the same auto parts warehouses the brick and mortar parts stores use.
If you purchase new spark plugs, DO NOT check the gap or attempt to regap them. They come pre-gapped from the factory and if you try to check/adjust the gap, you can easily damage the precious metal coating on the electrodes as it is extremely thin.
Old Jun 22, 2024 | 12:41 AM
  #29
did you follow the procedure in the service manual?
It covers just about everything you need to know.
https://charm.li/Chevy%20Truck/1999/...alance%20Test/
Old Jun 22, 2024 | 11:02 AM
  #30
thanks for the info. I'll try to get some new olugs in there and see if it helps. Not sure if it will effect fuel trim though.
