I made a video on my 454. changing intake manifold gasket, distributor, and more.
Old Jul 31, 2019 | 9:15 PM
davidt443's Avatar
Default I made a video on my 454. changing intake manifold gasket, distributor, and more.
2000 Chevy 454 vortec. I couldn't find a one all be all video for changing all these parts out. I replaced the intake manifold gasket, distributor, injectors, fuel pressure regulator, oil pressure sending unit, plugs, and plug wires. I hope this video will help any of you with a 454.
Old Aug 16, 2019 | 5:59 PM
davidt443's Avatar
Just wanted to post a couple notes after a few weeks after installing everything. If you buy the same injectors I did or even the expensive Bosch ones, you may encounter some issues like I did.
First off. The truck ran great. About 50 miles of driving the truck threw a code. P0172 and P0175 which are bank 1 and 2 rich codes. After doing tons of research, checking fuel rail pressure and talking to Five0motorsports that sells the Bosch injectors, turns out my MAF sensor was bad. I also installed a 195 degree thermostat. I've driven 250 miles since and haven't thrown a code. I also now get a whopping 12.7 MPG with 285/75/16 mud tires going 70 MPH. And yes that was calculated by pencil and paper.
davidt443
Aug 16, 2019 5:59 PM
SlackAttack
Oct 9, 2017 5:14 PM
flainn
Feb 14, 2014 11:22 AM
dj lpm
Feb 13, 2012 1:04 AM
Champ_Az
Mar 22, 2011 2:02 PM
