Interior electrical issues
Old Nov 22, 2019 | 2:57 PM
MikeySmiles's Avatar
Default Interior electrical issues
2004 Silverado Ext Cab. Trying to help a friend. Started with oil pressure gauge pinning on the high side. Then a/c and heater goes on and off intermittently ( he already replaced the control thinking that was the issue but it wasn’t). Then the battery went dead for no apparent reason ( it’s one year old). Then radio stopped working. He’s since found that whatever the issue, if he disconnects the battery the truck seems to reset itself. Up to now I thought it was a ground issue but after some research I’m leaning towards the BCM. Does anyone have any experience with these similar problems and did you try replacing the BCM ? Thanks for any help or suggestions.
Old Nov 25, 2019 | 4:50 PM
Thumbs down
Ok. Thanks
Old Nov 26, 2019 | 11:22 AM
BCM is low on the list of suspects for me, I would look at the neg and pos battery cables for poor or intermittent connection. The cable can look perfectly fine but put a meter on it and it is high resistance or intermittent connectivity.
jcharville
Feb 28, 2019 7:52 AM
Black2007
Sep 23, 2014 11:32 AM
SRanger
Oct 20, 2012 4:39 AM
fleshman77
Sep 17, 2008 3:36 PM
lightGear
Mar 20, 2007 6:41 PM
