Issues with 4L60E
Old Oct 15, 2017 | 7:18 PM
eodblaster1369's Avatar
Default Issues with 4L60E
Hello all, need some help here. I have a 2001 Silverado 1500, The transmission basically stopped working. I was driving along and the truck started acting very sluggish. Could barely make it up my drive way. So once I got home, I tried to pull it into the garage and it would not go. Would not engage in Reverse, OD, D, 3, 2, 1. Dead in the water. I pulled and checked all my fuses, I checked the fluid levels good. I checked the fluid levels prior to starting the truck and then while it was running. The fluid level indication was lower, I did this check to verify the pump was still working. The truck sat for about 2 hours, I started the truck and was able to move the truck to the garage. Once I stopped and put it in park, I tried the garage rotation and nothing like it was in neutral and revved up. So any help would be greatly appreciated. Thanks in advance.
