Lm7 loosing coolant without any leaks
Old Jun 10, 2018 | 12:27 AM
Giovanni Ruiz's Avatar
Default Lm7 loosing coolant without any leaks
I was driving the truck for about an hour topped off the coolant yesterday haven't driven it except for that hour. The temp gauge was jumping up and down but not much at all. Got home to check the coolant and it was all gone and I opened the coolant overflow cap and the tank overflowed and started spitting out a ton of coolant. Anyone have any ideas what it could be?
Old Jun 10, 2018 | 11:54 AM
tim_cleaveley's Avatar
is it coming out of the exhaust. Could be your head gasket.
Old Jun 10, 2018 | 6:54 PM
hicksvilleshick's Avatar
Are you sure you didn't have an air bubble trapped?
I like to open the system while it's cool before the thermostat opens, top it off and idle it until it opens the thermostat, add coolant as needed. I tend to let it run long, just to make sure it circulates as much as possible.
Old Jun 12, 2018 | 8:10 PM
bear69's Avatar
Default How to bleed the cooling system
change the radiator couple days ago losing coolant after maybe about 30 minutes or so boiling pullover put more water in temperature goes down to around 210 can only drive short distance can somebody please advise
Old Jun 13, 2018 | 8:09 AM
maybe an air lock, or faulty themostat
