loosening alignment bolts
Old Mar 24, 2024 | 11:27 AM
packdog's Avatar
Question loosening alignment bolts
Hello all,
My 2005 Silverado has, for maybe 8 or 9 years now, had a curious issue where after about 6-12months my upper control arm bolts (the alignment adjustment bolts) start to slip. This leads to a heavy clunk with low speed steering and when turning and hitting bumps. For example going from the flat road to my driveway has a gutter into a 5 degree up slope. I've been chasing this clunk for almost 6 years off and on and basically replaced all of the front steering/suspension components, but I've finally nailed down the source. The vehicle has not been in any accident to my knowledge.
Has anyone else had something like this happen? How can I keep the friction-fit tight?
What are the torque specs for these bolts? Since I've replaced the control arms/bushings in the past I may have messed things up; Is there a particular arrangement of bolts/washers? Direction of bolt head/nut v front/back of vehicle? Can I just put a 2nd nut on the bolt to lock it? Could this be an indicator of other damage I'm not thinking of? I mean, I've gone years at a time just "dealing" with the clunk, can I measure the frame slots to see if i deformed them?
Thanks!
Old Mar 24, 2024 | 1:57 PM
Originally Posted by packdog
What are the torque specs for these bolts? ... Is there a particular arrangement of bolts/washers?
Check on charm.li
Pappy Goodwill
Oct 3, 2021 11:24 AM
Mtmn2020
Feb 26, 2020 12:52 PM
Yogi
HHR
Dec 30, 2018 9:43 PM
advaqua
Avalanche
Jul 24, 2014 2:17 PM
ukrkoz
Feb 23, 2012 9:16 AM
