loss of heat
Old Nov 2, 2017 | 10:18 AM
mikej2013's Avatar
Default loss of heat
2002 Silverado 1500 4x4 zr1 5.3l Started using the heater the other night, where I once had heat on the temperature setting, I no longer have heat. I must turn the temp **** 50% to just get warmth. 100% seems to work fine. basically I have lost 50% of the operating range. I have a full coolant reservoir. I changed the inside air filter last year, but have not checked this year. I have air flow, that does not seem to be restricted. Any suggestions ?
Old Nov 2, 2017 | 4:48 PM
hicksvilleshick's Avatar
So your issue is it's not pushing heat at 25-50%?
I don't start getting any real heat out of mine until I'm more than 50% 50 and lower is the cold side, so I don't worry about it much, I mean it works, you can feel slight changes, but it doesn't really kick alot of heat til the higher end.
Dunno, I also run a thermometer in one of the vents so I just kinda run off that.
Old Nov 4, 2017 | 8:54 PM
mikej2013's Avatar
Just started this season. Last year as you entered the red zone heat developed. this year cold air until the **** is @ 12 o'clock, about half the dial range.
Old Nov 5, 2017 | 6:52 PM
Yeah, if you're not low on coolant, then I'd lean towards the controller.
Old Nov 7, 2017 | 8:48 PM
HunterManitoba's Avatar
Start with the climate control module , I’m sure you can find a donor truck with one that works properly.
