MAF sensor - AC Delco or Delphi
Old Feb 13, 2025 | 6:01 PM
Garon's Avatar
Default MAF sensor - AC Delco or Delphi
I may need to replace the Mass Airflow Sensor (MAF) on my 2000 Chevy Silverado 1500, 4.8L V8. The MAF also has the Internal Air Temperature (IAT) sensor built in. I usually replace these types of parts with OEM. My OEM is AC Delco and the price is ~ $160 on Rock Auto. I have also read that some of the OEM parts are Delphi which is available for $86. I do not mind paying the OEM price, but I was curious if people have had any experience replacing this with the Delphi part. I have included the link above.
Thanks in advance!
Old Feb 14, 2025 | 9:01 AM
jfmorris's Avatar
I cannot vouch for that specific Delphi part, but I have almost always been happy with Delphi parts in general, and would not hesitate to choose the Delphi and save some money. Delphi *USED* to be GM's internal parts division, but was spun off as a separate entity in the late 1990's.
Old Feb 14, 2025 | 5:23 PM
Garon's Avatar
Thank you jfmorris for the information. I have a rough idle start on cold days, but then idles and runs fine after 30 seconds. This only happens when the outside temperature is below ~50 degrees F. My diagnostics really don't point to the MAF / IAT sensor, but I was curious about the AC Delco versus Delphi part. I performed a smoke test and can see a small amount of 'air' leakage at the intake manifold gasket, so I will need to change that before firing the parts cannon.
Old Feb 14, 2025 | 11:16 PM
jfmorris's Avatar
I've replaced the intake manifold on my 1996 5.0L twice over the years. Both times it was losing coolant, one time rather spectacularly. I would definitely take care of that before the MAF.
I replaced the intake manifold gasket last summer while doing the knock sensors on my 2006 4.8L, and it was much easier on the GMT800 than I remember the job being on the older GMT400. Probably 2-3 hours total to pull the intake, replace the knock sensors, and put it all back together with a new intake manifold gasket. Sadly, one of the replacement knock sensors was defective, and I've got to eventually get around to doing it again...
keith20mm
Jan 1, 2020 10:02 AM
bedlam
Sonic (Aveo)
Aug 7, 2010 3:37 PM
Cpb200
Jul 18, 2010 6:19 PM
hos
HHR
Apr 3, 2008 4:52 PM
