View Poll Results: What is the reading telling me
Maf sensor is good
0%
Maf sensor is bad
0%
Throttle test is inconclusive
0%
Retest maf sensor
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
MAF sensor reading
I'm trying to diagnose my maf sensor. I conducted a test w/a DMM and the voltage was 1.96 I then tried to conduct a throttle body test by increasing the RPMs to see how it reacted, the voltage declined instead of inclining as most videos online suggested that it should. There was no slowness to react it didn't fluctuate up and down it just decreased. What does this tell me about my maf sensor and the reading that I obtained. Thanks for your time
Measuring the voltage across/to/through the MAF with a DMM is meaningless. You need a live data scanner to read what the ECM is seeing in terms of data from the MAF with respect to the reference voltage/signal the ECM sends to the MAF.
The live data scanner will then show you the amount of air going through the MAF sensor in terms of grams/second or the equivalent in English units. The MAF consists of a heated wire or wires and by the current required to keep the temperature of those wires constant as the air moving past them cools it/them, the ECM translates the current draw into mass of air flowing through the sensor and adjusts the fuel rate and the throttle body butterfly valve accordingly in order to meed engine demand.
So, in order to diagnose whether or not the MAF is functioning properly, you need the right tool to do so an a DMM is not the correct tool. Something like this:
paired with the Torque Pro app from the Google play store (provided you have an android device) is what you need.
Good Luck!
Good Luck!
what he said.
typically, with a warm engine at low idle...the maf should read approx the same grams/second as the engine displacement..ie 5.7l engine reads approx 5.7g/second.
if your fuel trims are within +/- 10 % and you have no maf codes...the maf is probably good. What kills mafs are bad quality air filter and heavily oiled wet air filters.
post the codes you are getting, symptoms, model year and engine if you want help.
Your maf should be at or slightly more G/S as it correlates to engine size in liters. I have a 5.3 so 5.5g/s is acceptable at idle. Cleaned maf and the readings went up but not high enough. Ultimately replaced maf and truck is not longer rich with rough idle and fuel trim is back to 3 or less in long term.
Get a good scanner that reads live data, watch your fuel trims, LT and ST should balance each other close to zero at idle. Clean MAF first, then recheck. G/s readings should be at or slightly above engine displacements.
it's not exact science but this process has worked for me with rich / lean issues on these trucks.
Learning about fuel trims tell you alot about what is going on
2017 silverado 1500 5.3l gas. P0171 p0174 and p0300 codes. Replaced maf, map, etc sensor, vent valve and purge valve solenoids, smoke tested intake emissions and exhaust and found no leaks. Fuel pressure dreams steady at 60lbs. Maf does underreport at 3 to 3.5 grams a second. Replaced it 3x
all report the same. Calculated MAF reading is nearly 6 grams/sec. I put 2 rounds of techron fuel treatment through it and seafoam the intake to clean valves. Need help. This is driving me crazy. Fuel trims are all positive and over 20. Underload they correct and go to 0 or close to which seams to be a vacuum leak. Nothing when smoke tested.
scrnchr
Jan 26, 2012 10:43 AM
