Miss firing issues
Old Aug 12, 2017 | 3:50 PM
ron36535's Avatar
Default Miss firing issues
2005 Silverado 1500 4.8 automatic.
Cylinder 5 is showing miss firing. I have replaced the fuel injector, moved the plug, wire and coil to a different plug that is not missing. I am still getting the miss fire ! help please.
Old Aug 12, 2017 | 5:19 PM
kevinkpk's Avatar
Miles? You might have a piston ring issue, can you do a compression check?
Old Aug 12, 2017 | 7:18 PM
ron36535's Avatar
90,000 miles. I would have to work on getting the tool for that.
Old Aug 13, 2017 | 8:40 AM
kevinkpk's Avatar
Have you looked at the spark plug?
Old Aug 13, 2017 | 1:10 PM
ron36535's Avatar
Yes, if you look at my first post, I swapped the spark plug, wire, and coil to a known good cylinder. also
checked wiring with a noid light.
