No spark After motor swap
Old May 6, 2024 | 5:35 AM
Jayden0529's Avatar
Default No spark After motor swap
I replaced my motor with the sane motor just a year new my truck is a 99 silverado 1500 4.8 ls RWD An donor truck was a 2000 silverado 1500 4..8 Ls Rwd An I am Getting no spark I've changed racks I've changed Wires Plugs r brand new AN GAPPED correctly crank sensor is changed Someone Told ne I need two get the pcm From the donor Truck because they are programmed to the vin? BUT IF that is the case Is the pcm Programmmed to the vin of the truck or vin or motor? OVERALL QUESTON IS Couldn't not have the donor pcm Cause my no spark
Old May 6, 2024 | 9:05 AM
frank1's Avatar
I just helped my nephew change heads on a Vortec engine, all that was left was the short block, it, the engine block, was the only part not changed out. After assemble she started right up. The computer didn't need reprograming and why would it need to be reprogramed anyway, there's nothing to reprogram. If it was running before the swap, it should still run. Sounds like you got an electrical issue, if no spark. When I do swaps I use parts that I know work, because I they worked before I started the swap. Did the original swapped out engine run before the swap ?
Old May 6, 2024 | 3:23 PM
Jayden0529's Avatar
the motor Had bad headgadket an Hydrolocked on me
Jayden0529
May 5, 2024 10:54 AM
Jayden0529
May 3, 2024 3:04 PM
Ragman33
Oct 16, 2012 8:11 PM
wmiller1337
May 22, 2011 10:15 PM
epekarik
Jul 14, 2006 12:51 AM
