No start after rebuild
Old May 31, 2017 | 1:48 AM
Southaven's Avatar
Default No start after rebuild
I have a 2000 4.3L engine and I replace the timing chaine, rings, rod & Maine bearings.. now I have 150 on compression, it fires, 65 psi on fuel. It back fire one time and it make a noise like it pumping. I set the cam at 6 & crank at 12 on chaine . I set The dis on the 6 mark after turning the crank too the marks no start
Old May 31, 2017 | 7:15 AM
Distributor timing is probably off. Maybe 180 degrees off.
Old Jun 2, 2017 | 11:29 PM
Digdug67's Avatar
Maybe crankshaft positioning sensor? That was my issue I had forgot to install it back after rebuild. Good Luck
