P0171
Old Aug 20, 2022 | 4:07 PM
Ivy05z71's Avatar
Default P0171
05 z71 5.3 extended cab.
Over the past few months my check engine light has come on and gone off multiple times. Didn’t think anything of it because the last time I checked it was a evap leak and I assumed it was my gas cap. A few days ago I noticed that it seemed a little off as far as power. Not significantly but I can definitely notice it. Took it to O’Reilly‘s and I’m getting a Lean condition in Bank one. The check engine light went off again but I can still notice the lack of power. I did the water bottle check over the intake manifold to see if I can notice any change and attempt to locate a leak But didn’t affect it at all From what I could tell. My next step is going to be to check the fuel pressure. I replace the MAF sensor a few months prior. If anybody knows of any good scanning tools that’s on the cheaper end of things that can show me the data capture from when the codes were thrown please let me know. Any tips tricks or information that would be helpful is much appreciated. Thank you
Old Aug 20, 2022 | 9:16 PM
oilcanhenry's Avatar
You have too much air or not enough fuel. Could be a bad fuel injector or a bad PCV system leaking air, or a bad oxygen sensor.
Old Aug 29, 2022 | 3:05 PM
Ivy05z71's Avatar
Nice call with the PCV system leak! Boot was old and cracked. Replaced it and she’s all good!
99chevy612
Jan 10, 2016 12:36 PM
tonyvisone
Mar 27, 2014 8:33 AM
bandit_601948
Mar 11, 2013 10:24 PM
nj85z28
Dec 29, 2011 1:35 PM
TS14
Jan 5, 2010 7:04 PM
