P0301 Misfire code
Old Dec 11, 2024 | 6:59 PM
Rigog007's Avatar
Default P0301 Misfire code
Back again but with another truck. 2005 Chevy Silverado 4.3. Driving home from work last night and engine light was flashing for 30 seconds felt sluggish, but then it went away. Hooked up the Foxwell and just came up with a pending P0301. Truck has a brand new distributor/cap/rotor, plugs and wires. Only thing i didn't change was the ignition coil and control module. My question is: will a failing ignition coil only give 1 cylinder a misfire or would it get all the cylinders to misfire at once? Truck has 219K miles. I drove the truck to work today and all was good no issues.
Old Dec 12, 2024 | 11:44 AM
Oldcat's Avatar
A failing ignition coil will affect all 6 cylinders. P0301 indicates a misfire on #1 cylinder. I would check the #1 spark plug. The porcelain may be cracked.
Old Dec 12, 2024 | 8:04 PM
Rigog007's Avatar
Will do and thank u
MADMech
Jan 18, 2024 11:22 PM
Frank T
2014 - 2018 (GMT-K2)
Mar 26, 2023 8:24 PM
Chevyidaho
1988 - 1998 (GMT400)
Mar 4, 2018 8:19 PM
Truck Lovin Girl
Mar 31, 2014 8:35 PM
cams 98 silverado
May 10, 2010 11:39 AM
