Rear end Squeak when in reverse
Old Oct 31, 2016 | 10:31 AM
acdblujns's Avatar
Default Rear end Squeak when in reverse
I have a 2000 Chevy Silverado 1500 Z71 with a serious squealing coming from the right rear end when going in reverse. I thought it was the brake pads getting low on me. Replaced the pads and parking brake pads, all is good there, I even replaced the rusted dust plate as well. Soon as I put it on the ground and started to back out of the drive, the same noise was there. I guess it wasn't the brakes. Any ideas? It's a pulsing squeak, squeak, squeak and increases in frequency as the speed increases. It's not a grinding or crunchy sound and It won't do it when I spin the wheels while the truck in in the air.
Wheel bearing, Pinion bearing?
Any help thoughts would be appreciated.
Thanks,
Pat
Old Nov 29, 2016 | 3:01 PM
Silverzbob's Avatar
I had the same promblem and went through the same steps as you and it turned out to be a bad universal joint
Old Nov 29, 2016 | 8:05 PM
This !!!!+1
