rear main leak after oil pan gasket change.
Old Mar 28, 2016 | 4:42 PM
robertbassin5@att.net's Avatar
Default rear main leak after oil pan gasket change.
I have a 1999 Chevy Silverado 1500 4.3L 2wd. I have changed the oil pan gasket that sipped oil around the pan and just a spot of oil here and there on the driveway. After the oil pan gasket change it now leaks out of the rear main seal after the engine is turned off. Only leaks about a tablespoon worth. Any ideas what would cause this issue?
